bodereous
jaybee
Member Posts: 128
I havent gotten a chance to work on one yet but where are the clean outs on the boderous boiler?
need adobe
http://www.buderus.net/literature/G115-IOM-01.pdf
If you have adobe acrobat you can read up further. Basicly you pull the front cover, open the burner door and remove the baffles. If you have never done one before have someone go over it with you. They are a nice boiler but experience is a plus.hope this helps
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
