LP M unchkin
Dof3
Member Posts: 120
I tried to order a LP 80T Munchkin and I was told to field convert the nat gas one. Any problems doing this that I should be aware of?
As long as
you have a digital combustion analyzer, you should be fine.
The T80 converts from nat. to L.P. by adjusting the throttle screw on the gas valve. No orifice change is necessary.
The folks at HTP can walk you through it if you have questions.
Hope this helps.
Mark H
Thanks Mark, I have 4 of these to install. It sounds pretty easy to do. I got the factory conversion kit today but I have not looked at it yet. I will read through it and call if there is a problem.0
