Pump Gaskets
What is good maintenance regarding replacing pump gaskets when using Cryotek anti-freeze? Since we usually replace when leaking, I was wondering what the norm from the Pros?
Thanks to all. Ed
  • EJW
    EJW Member Posts: 321
    Full flange
    I get the red full flange gasket from FW Webb. Also add Cryotek inhibitor to the solution you put back in the boiler.
