Radiant floor heating in a shower.
Dan Peel
Member Posts: 431
Low temp sources of course work best in radiant but don't dismiss the added heat available from a slightly oversized panel rad or towel rail. Do the math then match the equipment to the design load, you'll be impressed with the comfort results. Enjoy.....Dan
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=174&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I am looking at radiant floor heat in a residential bathroom. The custom shower (35sf+)will take up 1/3 of the room. It will probably be a tile floor. The load in the room is pretty high so I need the area. I can not think of a down side of using the shower floor in addition to the rest of the floor.0 -
Bathroom load
A related question - two of the bathrooms have much higher loads than can be handled by the floor at say 25bthu/sf. What supplimentary heat sources have been successful?0 -
Bath heat
Shower floors, walls, bath ceilings - all great places for radiant. Supplemental heat can come in the form of baseboard, panel radiator or hydronic towel warmers. You sure have no shortage of choice during a bath build, reno or upgrade. Enjoy.....Dan
Or like Dan said the wall or shower floor could give you that extra heat needed. Do the whole shower especially if its tile.
Shower walls sounds like a good idea. I like towel warmers, but in this case the system hot water will be from a ground source water-to-water heat pump, so the temperature is limited.0
