gaskets
ruth
Member Posts: 3
we have an oil furnace,baseboard hot water heating system. we are seeking a source for gaskets for our plumber to do the annual cleanings on our system. the system has the label "circle combustion" on the outside. any ideas for sources for the gaskets? RUTH O'HEARN
the boilers leaking at the gaskets right?
the gasket it self isnt an especially large degree of the fix.the minor technicalities involved removing and replacing them Thats where the "Catch"is sort to speak.0 -
whick gaskets
Which gaskets are you looking for?Annual cleaning? I'm thinking that your looking for the fireside gaskets? I've been making my own since Circle stopped suppling to my wholesaler.
gaskets
thanks. we are looking for the annual cleaning gaskets. our plumber has been making them for us but absolutely hates to schedule us for a cleaning because of the hassle. any idea for sources for premade gaskets? our plumber's supplier has stopped carrying them, also. thanks.0 -
where
Where are you located?0 -
location/gaskets
we live in southern vermont, between brattleboro and bennington. thanks ruth0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
