cast iron boiler leaking at the gasket. How do I fix the leak ?
Val_2
Member Posts: 4
An H.B.SMITH CAST IRON BOILER ,1,000,000Btu/hr ,is leaking between two sections.How do I fix the leak ?
Thank you Val Hvac technician
What model is it?
Is it steam or water and apox. how old is it?..Robert O'Connor/NJ0 -
It is a hot water boiler ,25 years old.
Thank you ,Val0 -
Lot's of man power
Either replace it if It's old or get ready to disassemble the whole thing and regasket it. Oh,..Bring lots of help. Strong workers.. good luck0 -
there is not much life left...
you should chuck it, and put in 4 250kbtu boilers with a stageing control - least expensive example: a slant-fin CARAVAN system
add primary/secondary/injection piping with outdoor reset and you will save a fortune0
