Buderus oil Venting question
Ted_9
Member Posts: 1,718
I know I should call Buderus on Monday, but here , maybe one of you knows this.
With the G115, we are venting through an all fuel stack. Is there a fresh air kit that goes right to the oil burner. If so which burner. I wanted to go with the Riello. Otherwise, would high low fresh air ducts work?
Ted,
There is a burner with a boot on the top. It's called the BF3(for the 115) and is used for their direct vent kit.
I would check with them on Monday anyway to see if it can be used for intake only. In the DV application, the exhaust heats the incoming air. Chris0 -
I just found in the price book where it says there is a fresh air colar but I think its only for the becket afg burner. I was thinking to go with riello.0 -
Buderus offers the Riello OEM burner with a fresh air intake only on the BF model (comes with the AL1009 pre/post purge control). This burner can be used in a chimney application, but requires some set up changes. Riello does offer a F series burner with the fresh air intake but that is not available from Buderus.
Carlin offers a fresh air boot that mounts on the EZ. Beckett AFG is available with a cover and an optional fresh air adaptor is available. Give us a call on Monday if there are any questions. 1-800-2833787.0 -
So, which is the easiest for this application?0 -
Best way
Either way will work. Air boot to the burner or high/low air vents.
I like the fresh air direct to the burner, but it is personal preference!0
