buderus g115
I am not sure if i understand this right but i was on the buderus website looking at the buderus g115 oil fired boiler and if i am not mistaken could i use a combination air intake/exhaust termination part# ft 4 i was going to use a power venter but if i can use this great
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    buderus....
    makes a concentric vent for their direct vent boiler w/ a special burner set up...if you use it follow the directions to a T...kpc
  • RoosterBoy
    RoosterBoy Member Posts: 459
    pics
    this is not mine but this is what it looks like and from what I here power Venter is better if you have more then 15 to 20 mile per hr wind facing the vent side of the house.
    unless you get the ft 4 then you can put the burners intake vent on another side of the building I just don't like 2 intakes coming out of my boiler takes up space
    i have had a power Venter on my furnace now for 3 years no problems.
    I am getting the g115 with a stainless steel power Venter it's much cheaper then going with the bf burner and the vent kits I will go with a 40 f3 riello and a swg-5 power Venter.
    thanks
  • dave connors
    dave connors Member Posts: 30
    intake air
    intake must always be placed on the same side of the house. never put the exhaust on one side and the intake on the other.
