trane or carrier for my air handler??
RoosterBoy
Member Posts: 459
trane or carrier for my hydro air handler for heat this year. both cooling and heat next year. what should i go with
my heating will be a buderus g115 boiler model 28 83,000 btu is my load and i need a 2 1/2 tone air handler
thanks
thanks
air handler
Both trane and carrier make excellent equipment. Pick the manufacturer that makes the unit sized closest to you needs. Also think about parts availability should trouble happen..if you buy the unit yourself, will someone come and service it?
Al's right
But you also need to look at the ARI ratings so you can get the most efficiency out of the cooling side.
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
