low profile baseboard
RoosterBoy
RoosterBoy Member Posts: 459
hi can someone give me the website to some low profile baseboard someone posted a good one here and stupid me i forgot to bookmark it thanks
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    Try..
  • BillW@honeywell
    Here are some...
    www.burnham.com, www.myson.com, www.slantfin.com,www.steamradiators.com
  • Ewan
    Ewan Member Posts: 45
    Is this the thread?
    Retrofit for CI Radiators
  • S Davis
    S Davis Member Posts: 491
    Runtal
    You might try Runtal these are their VLX7/7.
    S Davis
    Apex Radiant Heating
  • Dave Palmer_3
    Dave Palmer_3 Member Posts: 388
    "petite 7" is low
  • DaveGateway
    DaveGateway Member Posts: 568
    Sterling Heat
    The makers of Sun Temp, and Petite 7" also make a "designline" BB that's only 6.5" and it accepts a mylar accent insert on the front cover. Probably a lot cheaper then steel Runtals.
    www.sterlingheat.com
