Can you tell me about this fitting?
Jon S.
Member Posts: 43
I just want to know how old, how well they worked. Stuff like that.
Thanks
Thanks
looks more like
a eureaka type fitting to me..dans got info on them in his ''heating q&a section...i've never seen a monoflo fitting with duel ports.gwgillplumbingandheating.com
if its monoflow it should not work at all. . centers of tee's should equal length of radiation served.0 -
inside
if you look through the tee (either side). It has ramps that cover half of the pipe opening. The top (where the ramp is) directs the water through one of the branches. the bottom (under the ramp) is open. Its the same on either side. They were piped just like a monoflow system.
Hope this helps.0 -
I have one in my heating system at home.
It is a monoflow tee that feeds the radiator in what used to be the second bedroom, before the people before us put on the addition. We have never had any problems with the radiator not getting warm. I have always wondered about that fitting- it is the only one in the house, but we have never had any problems.
really
Geez guys- it's a little tree air freshener- looks to be of the spice variety.0 -
I agree
Eureka!Retired and loving it.0 -
From Heating Q&A
on the navigation bar.
It pays to wander off the Wall.Retired and loving it.0
- 167 Indoor-Air Quality
