funrnace wireind diagram
jaybee
Member Posts: 128
can anyone explain how a basic wireing diagram of a furnace from transformer to burner operation? Or if anyone have any lit that they can send me on this my e-mail adress is jessejr362000@yahoo.com.
jay
Get with Timmie of Gas Appliance Service. 1-410-437-0557. Timmie has service manuals for everything from basic to advanced.0 -
Start with basics
Take a look at Carol Feys books in the "books and more" section on the left. After that the schematics will make alot more sense. Basic electricity isn't. But, it's like a foriegn language, keep plugging away at it and one day it makes sense.0 -
forced air furnace.....
they pretty simple . for oil. the power goes to the burner motor and high voltage transformer .it goes...............a more sophisticated deal is to use a primary control . the power goes to the black on the primary the motor goes together with the transformer to the Orange wire. whites are tied together. tstat wires are lashed on the T T the yellow wires are the fireeye.F F ..........beyond that it is all about temp probes that turn the fan off and on at set temps called a fan limit switch. and safetys that shut the system down .if you have a primary with blue purple pink orange black white then these other wires are for intermmitent devises like oil soleinoid new style transformers oil pre heat motor control.power in and out.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
