wirsbro quick trac
brian_25
brian_25 Member Posts: 16
does any body have experiance with installing quick trac this is my first quick trac job i have 1 zone that we are installing that has 10 loops apout 180 ft room is about 30 x 34 how do i get my loop ends to a central location with out long runs in the basement
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    Well....
    you have to spend an hour or two piecing it together and getting a feel for the big picture...put the manifold in the middle and make sure you give your self a way to get back to the manifold w/out dipping below the floor... or as little as possible...try to do it out on paper before if you can...I have a chop saw nearby to customise the turns and lengths...kpc
  • Dave Yates (PAH)
    Dave Yates (PAH) Member Posts: 2,162
    remote manifold
    If you utilize injection mixing, you can move the manifold close to the loops and use small diameter tubing to inject the remote manifold. Works great & saves $$$ by eliminating long leader lengths.
  • John Felciano
    John Felciano Member Posts: 411
    Quick track
    You lay it out the same way you would a staple down,just it's a little more complicated because your locked into the 7" spacing.We have ripped the track to make for tighter near manifold spacing,but that gets a bit more tricky.
    It takes a few jobs to become efficient with it but once your used to working with it things go very fast.For the first one I would lay out a good part of it loose on the floor.Cut yourself a bunch of 90* turns (from the return strips)and start building it like a big puzzel.
  • Ted_9
    Ted_9 Member Posts: 1,718
    Thats a great example John Felciano.
    These are some more examples.
    This is Stadler/Viegas Climate panel, its the same product.
    Patriot Heating & Cooling, Inc.
  • John Felciano
    Climate Panel
    Another shot of tack piping before manifolds.
    The stuff is very versital and even fun to work with...
