wayne electrodes
jaybee
jaybee Member Posts: 128
Can anyone tell me what the distence of the gap @ distence out beyon the nozzle should be? also if u didnt have a gauge how do u set zdims on a burner if you have no specs to go by?
  • Weezbo
    Weezbo Member Posts: 6,231
    what burner ..?and howmany BTU's?
    and wihch one of how many nozzels? i'd like to say 3/16ths by 1/8 however it depends on ho buncha details.large boilers you best follow the manufacturers specs.i used to keep the cards in my bacharach kit.just so they would always be around.the nozzel or wholesalers will give you the card for free:)just ask.
  • Alan R. Mercurio_3
    Alan R. Mercurio_3 Member Posts: 1,624
    Jaybee, If you let me know what burner you're talking about I can send you a pdf file as an attachment or I can fax the info to you. what ever you feel comfortable.
    you can also check out the "Just For Teck's" section at Oil Tech Talk. there's information on Wayne burners there also.
    Just let me know how I can help?
    Your friend inn the industry,
    Alan R. Mercurio
    Oil Tech Talk
