How can I replace the leaking plate on the side of the boiler
EJW
Member Posts: 321
Need more info Tom.
Leaking rusted plate on the side of boiler
Can I replace the plate on the side of the boiler easily?
Can I get the part?
Should I use some sort of gasket or sealant to prevent it from happening again?
I'm sure some bolts will break off.0 -
and how old?
Weil Mcclain
20 years 0ld?0 -
Boiler plate
Can you post pictures??0 -
Steamer inspection plates?
Tom, if you are dealing with a steam boiler with inspection plates, the chances of removing the bolts are slim to none! I did a Burnham last spring that had both inspection plates weeping like a miniature Niagara Falls, when I tried to ease out the bolts, every blasted bolt head come off in the socket wrench. I removed the plates, ground the surfaces off flat, then center punched the bolts. You will be able to see them after you grind the surface flush. I used a series of drill bits starting with 1/8" and worked on up through 5/16ths. You have to be very careful not to drill all the way through the back of the casting! I then extracted the remains of the bolts and brushed the threads clean. Burnham had the replacement plates and gaskets but no bolts in the kit, so I got stainless bolts for the replacements. I cleaned the mating surfaces with alcohol, applied the new gaskets and plates, torqued the new bolts evenly and put it back in service. No leaks!! But it was very time consuming and messy, but it saved an otherwise good boiler from an early demise.
plates
Plates
You have your hands full with the rectangular one. The lower bolts will surely break off. I think you will end up doing what grumpy did in his post, good luck. EJW0 -
Damn..........
no wonder your Grumpy;)...........patience!Atta-boy!
cheese0 -
Even if you get the bolts out
I will bet the cast iron behind the steam coil plate is corroded away . It's not worth the money to try and get it to stop leaking , in my opinion . The Weil Gold is a fantastic replacement for the series you have , and I believe the tappings are all in the same places .0 -
Plate..
Thats the place where the tankless would be but isn't. If you've never done one before your in for a treat. Fortunatly on the Weil the end section is pretty beefy there, but be for warned you may break some if not all of them off. In the proper mind set and with some experience and the right tools you can do it. Without all of the precautions, you be buying a block....Good luck.......Robert O'Connor/NJ0 -
bit of a mechanic? .these are alot like exhaust manifold bolts
the exercise is about the same except you may need a few more tools and explicitives deleted to get them off:) first try to tighten all of them 1/16 of a turn...brush them down tap them with a hammer....spray liquid fire or w- d 40 or some such on them ... try to teweak all of them 1/8 th of a turn off spray plenty liguid fire on them again and bink them three times with a hammer again .....now if one or two seems to be comming off easily thighten the urination out of it...that will make getting the less friendly ones to give it up:) should they all make it off...get some catapillar anti seize some stainless bolts some brass nuts and some chubby flat washers.i like thru bolts bettern bolts persay...oh also when you put the gasket back take some grip and paint one side or the other with it...then the next time any one takes it apart at least the gasket will come away in one piece:) I would not deny Any one of the opportunity
)) 0 -
plates
got one to come out broke two and the other five seem to be rounded off !!
Grind them off or chisel them ?0 -
HowCome?
Why tighten the bolts, especially initially?
B4 you grind
No looking back now. Try vice grips.0 -
wondering
Now I am wondering how he made out?? I would not want to be in his shoes...although been there, done that, no fun!!0 -
Oh My! I feel for you!
Been there! Done that! Got the T-shirt!
they break --they break . move on
heat up with torch and let 'er rip. they break---drill and tap. standard procedure0 -
GeT the reverse drill bits:) out now
now your into it
the reverse drill bits ar the way ta cruise:) Have fun:) 0 -
plates
Thanks for the advice.Since I'm the HO, I guess I'll have til October some time before I need Heat!!0 -
You The Man:) it is a life experience like no other...:) as the home owner you will be in the lime light for bragging rites after this one:) your next oil tech will justabout HAVE to let you have the last word:) Good for you!0 -
Its not a real experience until its under a car on ramps or up agianst a wall. It could be much worse.
Matt0 -
Or maybe ..
Bad for you.
There is NO Guarante that the face of the boiler is not ruined from the leaking and rusting.
I would not do this job unless I told my customer there was no way of telling wether it would work or not. He would have to know that he may need a new boiler.
I think this is a huge job for a home owner to attemp and one which has very low odds of completion.
That being said, you'll probable show pictures two weeks from now with it all done.
Scott
Yup
Just Ta Spite you:))))
Hes probably got his reamers out right Now:) and he has already drifted the face with some carborundum paper rolled a glass rodd across it to check the face for any micro deviations from perfectly Flat:) wait till he tells us a thing or two!:)0 -
TomE
There was a commercial on TV not too long ago, I belive it was a Price Pfizter faucet spot that showed people holding up signs that said "I Just replaced my faucet". Tom, if you pull this off, I'm gonna make you your own sign. Don't take it the wrong way, I'm acually rooting for ya. Take your time..Robert O'Connor/NJ0 -
check it out0 -
check it out0 -
boiler plate
I have heat0 -
I have heat.It didn't take this long but I did have one small problem.
Why do they call them E Z outs?0 -
> have one small problem. Why do they call them E
> Z outs?
