System 2000 Really All the Add Makes It Out To Be?
T. Traceski
Member Posts: 8
I am looking to replace my home hydronic heating system (an old inefficient, but tried and true cast iron boiler) and separate NG domestic hot water, when I ran across an add on the System 2000 (Energy Kinetics). The brocuhure makes the system sound like everything you would want from a condensing boiler (high efficiency, stainless steel vs. cast iron, direct vent, etc.) without the associated cost or condensate disposal. Any views on the performance, reliability and even the cost of System 2000? Are we looking at the hybrid 'conventional' boiler of the 21 century or just marketing hype?
They back up the hype
It is all it's made out to be. You'll be very happy and warm w' the S2000. Plenty of Dom h/w from the 'plate type' heat exchanger.0
- 50 Industry Classes
