Top Ten List for Equipment Failures
Kal and Jim
You have both been awarded the flying fickle finger of fate!!!
Gary from Granville0 -
Failures
My Knees ,Back, Eyes ,Elbows, Wrists, Neck, Ankles, Feet, Teeth
And finally the mind. Oh, my mind still works. In fact it is just like a computer, but the delete bin is getting huge.!
Silicon Carbide ignitors...
The Norton company claims to have drastically improved their ceramic-intermetallic mini ignitor, which is composed partially of Silicon Carbide (mixed with Aluminum Nitride and Marley-Disilide). This development was introduced on their 240 volt ignitors. Maybe Kal and I will be sharing our Flying Fickle Finger of Fate Award with them?0 -
ahh, you kill me...
as i understand it, the advantage to the mini-igniter is less thermal stress gradients due to it's small size - so it heats and cools evenly and doesnt fatigue break but bob is right, for 24v you have to make the coating real thin it would have to be a micro igniter then you have to worry about oxidation effects cause you dont have enough thermal stabilizing sub-mass like trying to make an open air light bulb and imagine sizing safety valve for such tight current flows - fuh-git-abow-eet
Ya vull, heir commandant!
Ve haff vergotten about eat. Unt now let us go back to the laboratory und haff a leetle schnapze...(Young Frankenstein)
These HSIs are a nightmare in certain applications. Oxidation is one problem that seems to have no solution. They come in 24v, 120v, and 240v, by the way - but I don't think any of that matters. I'm not thinking that "our" award is a prestigious one, Kal!0 -
dots fronkenshteen
Amen to that!...
...I think I know how Evil Knevil feals in the morning!!!...0 -
Looks like John has some research material...
for an article on lunacy too, now.
"Hearts and kidneys are tinkertoys, I'm talking about the central nervous system !"
Class is.....dismissed0 -
Hmmm
I forgot the question.0 -
cm'on glen that was a long time ago - time to forgive...
they make great stuff now0 -
I'll never forget those things,
especially considering how much FUN it is to change the HX on those. Plus when you consider how much of a screw up those things turned out to be, its hard to forgive.
I will admit that Rheem has finally come along with some decent equipment for the 21st century. Hope it stays that way because everything they made in the 90's was a total failure, IMHO.0 -
Hot surface ignitors
I have never really figured out why these devices are believed to be useful. An intermittant spark, with or without a temporary pilot (for the duration of the burn), seems to make more energy sense. Gas appliance manufactures do not seem to pay attention to electrical energy costs.0 -
You are right Harry...
Costs considered by Manufacturers are primarily manufacturing costs and warranty costs. The customer base (present company excepted) really give very little concern to electrical energy costs, so manufacturers who focus on this area are not rewarded.
Bob Tonner
President
InfinityLab Inc0 -
One more time...
...with gusto!0 -
wow, I forgot about the Amana \"Energy Command\"
"thingies". I put one in a relatives house. Set it up and it ran great. The motor took a dump once when I was out of the country. They have since moved, and I am not banging on the new owners door!0 -
Bump
anyone remember the GE furnaces with the cast-iron
heat exchanger? What a monster that was.
Here in humidity land, we often get ac coil drain lines to plug up, and drip down into the 80's/90's BDP/Carrier furnaces that had the board in the blower compartment with the molex going through the cabinet to the top of the board. What occurred next was that the water would drip on the board, short out the connection there, fry the wiring harness, and short the gas valve. My first one I burned up a second transformer before I realized that the gas valve was gone. A few folks wisely chose a new appliance.
You can also count on Trane, and York equipment to toast run capacitors. Carrier runs a distant third in this category. Pretty much, if you find a "super-boost" on a system that has a flow restrictor type metering device, you can bet the run capacitor is bad.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
