Copper pipe reamer
don_42
Member Posts: 42
I was wondering if you guys know if they make reamers that
can be put in a cordless drill?
For 1/2 to 11/2 copper pipe.Boy my hands just hurt when I
use the one on the tubing cutter.
Thanks in advance.
Thanks in advance.
Believe it or Not
I can't seem to find one. I'm guessing that the relatively high speed of even a VSR cordless drill would make the thing unstable and/or dangerous.
Have you tried one like the top "inner-outer reamer"? Much, much, much nicer, easier and quicker than the ones on the tube cutters.
Rigid Reamers0 -
Reamer
Small pipe I use a tapered mechanics reamer ( Snap On ) , or what I really like is a Unibit
I've Only Ever...
...actually seen one, but I've seen pictures of several in old books - a reamer cone attached to a carpenter's brace. It's kind of a cordless drill, when you think about it0 -
reamers
check out imperial eastman tools they carry a small hand held inner outer reamer for up to 1 inch all metal and alot better then the ridgid models it,s all good for the forearms it's what makes men men peaceR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Thanks guys
for info,I'll check them out.
Bite the copper bullet....
and get yourself one of those handy Rigid copper pipe prep machines. It comes with a reamer attached, and a cleaner, and a cutter. Worth every cent...
In the mean time, I agree with the recommendation to buy yourself a Uni-bit. Once you learn how to use it properly, you can hold scratch cloth in one hand, and clean one end while you're de-burring the other end with your cordless VSD drill!!
Work smarter, NOT harder!
ME
dont buy the emt inner outer reamer for copper....
i thought yah thats the ticket! boy was i wrong:)0 -
We use
A chop saw to cut copper and use a Ridgid inside/outside reamer (metal) to clean up the burrs.Not a whole lot there to ream,but it works fast and does a good job0 -
Rigid Reamer
I use the same reamer , the iner works find but is it me the outer side grabs ,twists and jams?
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
