Spring Special!
Firedragon_4
Member Posts: 1,434
Okay, last month we had the new book on Primary Controls and again for all those who ordered thank you all very much and I hope you're enjoying your book and your multimeter!
This month we have another deal. Buy our book, The Hot Water Handbook', that always seems to answer so many questions that come up here and at 'Oil Tech Talk' and get our book 'Basic Air Conditioning Systems' for just $5.00 more. That's a savings of 20.00!!! But there's more.
We'll also throw in one of our Firedragon Ductulators and a 7-in-1 Screwdriver. We all know this is a handy tool to have in your possession. It has a removeable holder that holds 2 phillips heads, two flat heads and two posi-drive heads, nice for Riello's. Bits can be stored in the bit holder or in the convenient storage compartment in the handle. That compartment also works great to hold small screws and stuff too! Finally, the tip of the shank is magnetized to keep the bits from falling out and also works as a 1/4" nut driver, AMAZING.
This is normally a total value of over $75.00, but you can have it for only two weeks starting March 15, 2004. On April 1, 2004 it's over!
Just go to our one and only order form and in the NOTE box write in 'Spring Special, we'll take care of the rest for just $30.00!!!!
Go here now: http://www.firedragonent.com/order.htm
Thanks Dan!
Thanks Dan!
Small problem!
This package sells for $35.00 not $30.00, sorry about that!0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
