Slant fin Hydronic Explorer question
Ted_9
Member Posts: 1,718
Im trying to experiment with different water temps. For example, Im going from a 180 baseboard design to a 150 degree design. I see no change in the baseboard lenths though.
Im using a condensing modulating boiler and Id like to size the BB using 150 degree water without reset or outdoor temp controls. I just figure suppling at 150 should get the return to under 137 to keep the boiler condensing to get the greatest efficiency.
Hydronic Explorer 1 had trouble doing that
It was one of the first changes that we made when we developed HE 2.
Try this: After you change the water temperature, change something on the room data page. Change a room length, or something. This should make it recalculate with the new water temp. Then change it back to the correct number. It'll calculate again.
ORRRRrrrrrrr, go here:
http://www.slantfin.com/he2/
Noel0 -
I just downloaded it and Its a nicer program. Thanx.0 -
I have been assured it will be here ANY DAY NOW )))
it Bites being in alaska:))) slant fin three will be out for it ever gets here:))) i check my mail every day ....I am an Optomist...optometrist something like that0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
