Insulated conduit
J Matthers_2
Member Posts: 140
I am running piping for my pool about fifty feet underground from a heat exchanger in the basement. Looking for insulated conduit large enough for 2 supply and return. Any suggestions?
Re: insulated piping
You can buy pre insulated sleeved piping from several companies, it is sleeved then foamed in place.http://www.urecon.com/. They make a procuct call pexflex and copperflex.0 -
I use
this insulated PVC product www.insul-seal.com. they will insulate and cover just about any pipe material and any insulation thickness. i used the 3 and 4" for a sleeveto outdoor wood fired boilers. I run supply return, and a wire condiut inside. Usually a spare also
hot rod
Outside boilers
When at the trade shows the outside wood boiler people have this on display, you may want to contact a vendor for that product.0 -
Both good suggestions, Thanks0 -
I use
this Insulseal product. Bbasically a PVC pipe with a R-10, or R-17 foam and jacket applied. The offer sch 40, 10 foot lengths, in a bunch of sizes. I use it as a condiut to slide my PEX lines thru.
www.insulseal.com or 507 378-4131. Talked to the factory today, although the website seems to be having problems.
hot rod
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
