Vitodens Thru the Roof?
Van
Member Posts: 11
Has anyone had experience installing venting for Vitodens through the roof instead of out the side of the house? Or what about running the Viessmann venting up inside an existing unused flue? If so, anything to watch out for? Due to constraints, venting out the side is not practical.
Done one roof vent. The termination is different. Check with your rep or them for details.0 -
through the roof
Works great. Follow the guidlines in Viessmanns latest instal manual.
Two approved ways now! Sealed combustion using Viessmann concentric vent OR AL294C using building air for combustion.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
