point of use
erich
Member Posts: 2
We are an architectural company that specializes in healthcare projects.
(Outpatient Oncology centers-10,000 sf with 4-6 toilets in each facility)
Could you suggest a few products/ manufactures with features that would be
valued in a healthcare setting? We are interested in using point of use heaters
In a project that has a willing client?
What do you mean
by point of use equipment?
That is a broad statement that can cover a ton of equipment.
Are you talking specifically about space heating or domestic hot water?0 -
My reference to point of use equipment was for domestic hot water heaters.
Erich0 -
Are you looking for point of use heaters for individual sinks? If so try www.ProTankless.com and look at the Powerstream POU heaters. If it's tankless you want (1 or 2 instantaneous heaters) try Rinnai @ www.foreverhotwater.com.
Hope this helps.0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
