Don't Know How to Solder
and the "irrigation specialist" had to tie in to the copper domestic water system.
I've got to hand it to the guy; he used epoxy to join the fittings which provided a threading point for his PVC. It lasted more than 10 years until we came along and re-piped the bathroom.
But now, someone has come along with a product you can buy:
http://www.justforcopper.com/cb1b.htm
Watch out, ProPress
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Matt Undy
    Matt Undy Member Posts: 256
    I read an article about using epoxy instead of lead solder in Popular Mechanics about 15 years ago when they were first baning lead solder in potable systems.
    Matt
  • jim lockard
    jim lockard Member Posts: 1,059
    solder
    I went to career day with my friend a plumber where we had great fun teaching 4th graders to solder 1/2 elbows on to little pieces of copper pipe. Looks like this guy could use a lesson. J.Lockard
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Read an
    article in yesterdays paper about the Hardware show in Vegas where someone has come out with a product to "glue" copper together.
    It is some type of liquid compound that wipes on the pipe, in the fitting, you give it a couple of twists and it hardens up.
    Has anyone else heard of it or seen it in use?
  • hr
    hr Member Posts: 6,106
    Yes, Jack
    I did see that product at the Homebuilders Show in Vegas this year. It was at a Home Depot booth and display.
    Sorry I didn't have a camera that day.
    hot rod
  • Kal Row
    Kal Row Member Posts: 1,520
    \"copper weld\" is a one way trip, just like propress
  • Jimmy Gillies
    Jimmy Gillies Member Posts: 250
    Copper pipe glue.
    Alan.
    I had a look at the product you gave the link to.
    Has anyone used this product?
    It looks a great product. Could it be the end of soldering?
    Thanks Alan.
    Regards
    Jimmy Gillies
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    My dad fixed a leaking lead and oakum joint in a horizontal soil branch in his house with Quick Crete--at least 30 years ago and it still doesn't leak or clog. It ain't pretty but I've gotta' hand it to him for ingenuity and long lasting "quick fix".
  • Dan_12
    Dan_12 Member Posts: 9
    glue make a mess
    Had a contractor use so much of this stuff he plugged up a pressuring balancing shower valve. A little torch work got the stuff out, said it was the second time he's had this problem.
