Pressure drop thru copper tube
Paul Rohrs_2
Paul Rohrs_2 Member Posts: 171
I have found a spreadsheet to calculate pressure drop in a system. I am really looking for a Simplified version for some bigger projects. Again, simplified is the key word.
I would like to be able to type in as variables:
Copper Tube Size
GPM
Flow rate
Pressure drop
It would be nice to change any parameter and see the resulting change with the other variables. I attended a copper clinic years ago and have a flow-rate, velocity, and pressure drop chart that I use almost daily. It would be nice if it were in spreadsheet form. I will post that later this evening after I scan it in.
Any thoughts would be helpful. Also, this might be great to have in "The Library".
I have job developing that will have large volumes of water that I need to calc the pressure drop which affects my flow rate, velocity, recovery time, and how many storage tanks I will need for peak conditions.
Regards,
PR
