National Radiator Company's No. 2 Oil-Fired Boiler
Rich Guibilo
Member Posts: 2
The PDF file from the Library displays for a few seconds and then goes gray with an error message. This occurs with many of the PDF's in the Library but I am very interested in this one in the oil fired burner catagory. Can anyone help?
This sounds liek some issue with acrobat and your web browser. Try right clicking on the link and saving the file, then try to open acrobat and open the file. Perhaps that will give you some clues as to what is wrong.
Matt0 -
It comes right up for me
Are you using the Acrobat 6.0 reader?Retired and loving it.0 -
Thank You
I had the 4.0 version. When I downloaded 6.0 everything was fine. Thanks. This is a very good web site.0 -
Thanks!
