News from B&G
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,687
BELL & GOSSETT" INTRODUCES NEW 70X PRESSURE BOOSTING SYSTEM
Morton Grove, IL.May 13, 2004 - Bell & Gossett has introduced the new 70X variable speed pumping system for pressure booster applications. 70X packages are designed to provide low initial cost, outstanding reliability, and lower life cycle cost.
Using the latest proven software technology, the 70X introduces the concept of combining a variable speed lead pump with one or two constant speed lag pumps. The 70X allows the operation of multiple pumps in parallel, discharging into a common header that supplies a domestic water piping system. Variable speed pumping allows the discharge pressure of the pump to precisely match the actual system requirement.
A typical 70X package includes up to three vertically mounted Bell & Gossett Series1531 pumps with a check valve on the discharge of the variable speed pump, and one or two constant speed lag pumps, each with a pressure reducing valve. In common installations, such as multi-level buildings and schools, the system adapts to water needs as they vary over the course of the day and throughout the changing seasons.
The 70X system is controlled by the Bell & Gossett Technologic 500X pump controller that combines a variable speed drive and pump controller. The Technologic 500X uses a combination of kW, pressure and speed to calculate the most efficient operation and maintain a pre-programmed set point.
With its variable speed lead pump, the new 70X can obtain energy savings unmatched by a constant speed booster. The energy and operating cost savings with the use of the 70X variable/constant pressure boosting system can often produce a payback of energy cost within a year.
Designed with ease of installation in mind, the 70X requires only suction and discharge connections and one power connection. It also requires minimal floor space and can be transported easily through doorways, making it ideal for retrofitting.
About Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, hydronic specialties, heat exchangers, condensate handling equipment, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone +1.847.966 3700; fax +1.847.966 9052; or visit www.bellgossett.com.
Retired and loving it.
  • DaveGateway
    DaveGateway Member Posts: 568
    Way to go B&G
    VSI comes to booster pumps! I think there will be some happy building owners in this system's future. Seems like a real energy saver to me.
  • Shelby
    Shelby Member Posts: 38
    Seen them putting the packages together.
    I was at a trade show in Chicago in the fall of 2000 and had the chance to tour their plant. Wow that plant is big. I was supprised how many different components are put together under one roof. Their Booster pump package assembly area is just a small area on the floor there. They take great pride in their work and the booster packages look great when they are put together. I used to build some components on their 70E series but had never seen what a completed package looked like. I took great pride in the work that I did and it was nice to see that they took the same pride in their's. They sure have some nice looking product.
