Bryant conversion burner pilot parts
A. Blake Cooper
Member Posts: 20
I have a Bryant conversion burner type 3-94 w/ Bryant Thermo Pilot Model 700 pilot. The pilot controls the open/close state of the circuit on it's terminals(obviously depending on the thermal state). Where am I going to find a new thermocoupler(or other parts yet to be discovered) for this? In the case that I'm out of luck, what device would be my best choice for creating a replacement unit?
Baso
While there are baso type switches still availabe it's usually less expensive just to replace the gas valve with a combination valve.0 -
That pilot is a bi-metal pilot
not a thermocouple. Where are you located? There is a replacement but it should really be installed by a professional.0 -
i believe johnstone supply carries a replacement but as stated by tim it should be installed by a professional.0 -
Located in Northwest Indiana, can you recommend someone?0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
