Small diameter air systems
Steve_43
Steve_43 Member Posts: 1
Just looking for thoughts on what the prefered hi-pressure air system is out there. What is everyones opinion on: Unico, Energy Saving Prod.(Hi-V), and spacepak?
  • Big Ed
    Big Ed Member Posts: 1,117
    Hi Pressure
    If you can not install a low pressure system the hi pressure systems are a God sent....But it will cost you.
  • Ted_5
    Ted_5 Member Posts: 272
    Don't forget AirLink by Heatlink!
    Pressurized duct system with a twist. Check it out!
    Ted
  • Tombig_2
    Tombig_2 Member Posts: 231
    Mini Duct
    I have had much success with Unico. Whichever...DO YOUR HOMEWORK. This is not your father's AC system!
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    HI-Velocity Air?
    Go way over the distance needed on the return. By using more return ducting cuts down on the noise these systems inherently produce.
  • heatboy
    heatboy Member Posts: 1,468
    Ted, does Heatlink.....
    offer design software for both radiant and high velocity in the same program?
    hb
  • Nron_9
    Nron_9 Member Posts: 237
    Hi V systems
    We have had good success with Unico. Take the training if they have one. If you don't, they make you look dumb. As to design software, some reccomend Writesoft. Just looking at it now, kinda pricy. Any one used it yet?
  • Unico,Energy Saving Products
    Our company has sold both systems to contractors for the last 6 years with great success on both systems. I was out with a contractor last week were we supplied 2 systems. 1 up stairs and 1 down stairs. with the systems running and the house up to temp (68deg) we checked the temp in every room of the house and found no temp differance over 2deg any place in the house. Try that with a conventional system.
  • John Mills_3
    John Mills_3 Member Posts: 221
    Remember
    these things reduce capacity and SEER. Unico & Space Pak are ARI rated with many outdoor unit so study them carefully. You often end up 1/2 to even 1 ton under what the outdoor unit normally does and can run 2 SEER points below. So those guys putting 10 SEER outdoor units on Unico are really selling 8 SEER though around here anyway, customers aren't informed of that. Most 12 SEER outdoor units ARI rate at 10 SEER. Last I knew, those were the only 2 ARI rated. Not sure how you'd know your end result with the other companies.
  • Tombig_2
    Loss of SEER?
    > companies.
  • Tombig_2
    Loss of SEER?
    John, is this coil/condenser SEER data available? I would like to see it. I realize that manufacturers use orifice expansion devices and precise airflow to achieve SEER. Unico and others use expansion valve coils which operate at lower temps which in turn increases dehumidification. That allows you to set your stat a couple degrees higher for cooling and still be comfortable. Sound familiar, Wallies? Does your rating consider system efficiency as well as equipment efficiency? In my opinion, it's the delivery system that makes the job, not the equipment. Have you ever installed a 12 Seer unit in a house that was ducted for heat only? What a waste of initial cost and efficiency.
    We're hydronic guys here and mini duct AC systems are a natural progression of our trade. This is the first I've heard of reduced SEER. I really think they perform well for AC only. Just My Honest Opinion
  • David_5
    David_5 Member Posts: 250
    Loss of SEER
    The reason for the lower SEER is because the air is colder. Colder air means colder evaporator coil. That means lower suction pressure and a higher compression ratio for the compressor. If you ask Unico they say you loose 2 SEER. However the fiberglass ductwork is much less leaky than metal ductwork. The SEER does not tell the whole story. I have a Unico system in my house for heat and A/C. I would and do recommend it. I am looking into Spacepak because they offer 100' rolls of duct and Unico only has 25'.
    David
  • Reynz_2
    Reynz_2 Member Posts: 98
    Unico
    Great information on the system. I have a couple of contractors coming to give me an estimate. Anything to look for to determine if they really know what they are talking about, and are truly familiar with the system?
    It would be hard for me to know if they really know what they are doing or not. Any information you can provide would be great.
    Two comments by contractors on phone calls, costs are about $3500 to $3800 per ton, and if a H/L type calculation for cooling determines, for example 3.5 tons, they round up to 4, because a Unico system can handle a larger size better than a convention system. The conventional wisdom, is that over sizing is bad for conventional systems, but the Unico system can handle it. From what they said anyway.
    Seer???? Hum, will a 15 SEER rating actually give me a 15 SEER performance? What size do I really need for good to great efficiency. I’m very interested in efficiency and low operating cost. Thanks, Reynz
  • Ted_9
    Ted_9 Member Posts: 1,718
    I have install all 3 and I like the ESP Hi-V.
    BTW John Mills , I beleive the ARI charts for the HI-V shows an increase in SEER, at least for the Lennox units.
    Also to note, the Air Flo 10 SEER condenser may have gone down in SEER by half a SEER.
