Out with the old ..... In with the new
Tom Simensen
Member Posts: 74
I was hired last week to re-pipe this boiler room, and to install a new boiler. With noise being the primary reason for the change out, I chose the W/M Ultra 230.
If it wasn't for the temperature rising on the display, you would hardly know the unit was running. I am confident that we took care of their noise complaint, and hope that they can see some other benefits to this new technology in the years to come.
Tom
Tom
outstanding
Beautiful job tom that set up is awesome, excellent quality the home owner should be over joyed to have some one as capeable as you to install there new system totally professinal job take a bow just one question why didn,t you mount it to plywood aside from that it's a work of art to my eyes keep up the excellent work good luck and peaceR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
That is one handsome job there, Tom. Looks like it was a very comfortable place to do the work...alot of elbow room.
Pat yourself on the back,Sir,you deserve it0 -
Nice work
looks like a DHW expansion tank on the old Loch!
Good luck on your RPA bid.
hot rodBob "hot rod" Rohr
Great work
A neat, logical installation speaks for itself. While the previous job did not look like a hack job either, this setup offers a more logical path for the eye to follow, as well as visual feedback at every branch (the dials). Great!0 -
Simply...
Incredible Great workmanship.You are a credit to our industry.
John0 -
Sweet!!!!
Great looking job... no problem with flow through that boiler!!!!
Looks like you also switched a bunch of zone valves for pumps...bet that will make a noticable difference in the heating also.....
Floyd0
- 167 Indoor-Air Quality
