boiler
Billy_3
Member Posts: 42
I usually unbolt the flange and stick a screw driver in between and pry up until I get water and it usually gets rid of any air bubbles
burnham boiler question
I installed a Burnham Rev. sealed combustion .
I hear no air exept at the boiler ,in the built in primary loop pump.any way to bleed it? Help.0 -
i mean loosen the bolts
I loosen them not unbolt them0
- 120 Geothermal
