RADIANT HEAT TEMP.
CHRIS_26
Member Posts: 1
I'M INSTALLING A NEW BOILER IN A HOUSE ABOUT 40YRS. OLD THAT HAS COPPER RADIANT HEAT IN THE FLOOR (CONCRETE) AND CEILING (PLASTER). WHAT IS THE MAX TEMP. THE HIGH LIMIT CAN BE SET WITH OUT DOING DAMAGED TO THE COPPER,CONCRETE, OR PLASTER.
that sir is a Loaded Question.
let me ask ,what temperature was it previously set at? then Go with it. the answer has a group of liability lashed up to it...say some one said 130¡ãAND everything Leaked then you could basically lash out at one of us for giving you that number...i kinda dont want to even suggest a temperature specifically for that reason.
- 167 Indoor-Air Quality
