American Standard Boilers
RonTC
Member Posts: 13
Can someone tell me on where can I get parts for a Model A36M Series 2BJ1 Steam Boiler? Ron Hartzheim Town & Country Mechanical Richmond, VA 804-330-9006
What parts do you
need? Am. Std. sold out to Burnham somewhere around 1972! Maybe some one could help if you were more specific.0 -
I need a steam to domestic hot water heat exchanger0 -
IF !....
You are successfull in getting all the bolts out of the A/S block without trashing it, you can look to Heat Transfer Products for a coil. If that doesn't pan out , you can try Thermal Flow in Watertown Ma. I believe they made the original coils for this boiler. Best of luck on the coil. If it doesn't happen and the boiler HAS to stay, I would highly recommend an indirect, with a control that will maintain some temperature. This puppy's been warm since the day it was installed, and letting it go "cold start" will guaretee a leaker. (personal experience). Chris0 -
A New York outfit
named Central Water Heater - Diversified Brazil probably has one in stock. I believe they're in Queens.
(718) 417-9700
Thanks
Thanks everyone for your help. Ron............0
- 110 Chimneys & Flues
- 106 Geothermal
- 983 Plumbing
- 387 Solar
