Sulphur odor from the domestic hot water only not the cold, how
Bruce_9
Bruce_9 Member Posts: 6
Sulphur odor from the domestic hot water only, not the cold. How come? What can be done to get it out?
  • Ken_8
    Ken_8 Member Posts: 1,640
    The problem is simple...
    The zinc (or aluminum) sacrificail anode inside the heater is "toast" and dissolving in a "last gasp" attempt to reduce ionization (call it rust) from occurring inside the water heater.
    A trace scent can occur when the anode is almost all used up.
    If the rod is not totally spent (sounds like it's very close) you can get a replacement anode.
    I urge you to get one and install it before the water heater self destructs. Flush all the junk out of the bottom drain and rinse throroughly to remove whatever traces of the crumbled "rod" may be left inside.
    Let us know how you make out. You'll know all you need to - when you see what the new anode and old one you remove look like in comparison!
  • Tom Meyer
    Tom Meyer Member Posts: 300
    Anode rods
    When you go to get the replacement anode rod, make sure you get the one with the correct composition for your water system. Ask your supplier. They should be able to help you.
    Tom Meyer
    Senior Designer/Trainer
    Precision Hydronics Corp
    www.precisionhydronics.com
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,012
    anodes
    Hello: My understanding of things agrees that the anode is largely the culprit. It produces hydrogen gas as a byproduct of protecting the tank. This gas is "food" to anerobic bacteria in the water. The bacteria in turn create the rotten egg odor. Magnesium and aluminum anodes are commonly used. There is a special anode for odor that has about 8% zinc, in aluminum. So, to fix: Flush the tank. Add 3%hydrogen peroxide, (one to two pints per 40 gallons) and put that zinc/aluminum anode in. Peroxide is simply highly oxygenated water. That extra oxygen kills off the bacteria in a way nontoxic to us, so there is no need to flush the tank after treating it. Hope that helps.
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    Cathodic Protection..
    It's kinda like getting to the totsie roll center of a totsie pop. Unfortunatly for you, It stinks. Change the rod. Robert O'Connor/NJ
  • Weezbo
    Weezbo Member Posts: 6,231
    :) Oops..
    Hold on just a second,how long have you had potable water?..........what i gather is the majority of us have jumped to the conclusion this is just something that Happened on Sunday morning while making tea ,for the vicar:)......... What if its a brand new system guys....
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    Have you by any chance
    had a water softener installed recently?
    Mark H
  • ScottMP
    ScottMP Member Posts: 5,882
    Ive had
    that problem witha brand new tank. Had the same tank installed across the street with no problem.
    Had to change the anode to a differnt rod and the smell went away.
    Do they make anode's for underwear ?
    Scott
  • steve gates
    steve gates Member Posts: 329
    testimonial
    I got your book! I know the remedy works cause I did it to a tank just 3 weeks ago. Thanks
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Underwear weith Activated Carbon
    Scott, recently saw an ad for dog underwear with activated carbon that reduces or eliminates odor from dog farts. Should be adaptable to your needs. Could there be a better example of technology meeting the need?
  • eleft_4
    eleft_4 Member Posts: 509
    Ive had.... that problem
    Scott,
    I always expect to see some sort of a crack from a plumber.
    al
