slab over slab
kev
kev Member Posts: 100
I know this is an old question but, 4" concrete slab with 2" of insulation both under and along edges. Now they want radiant heat. If we poor over this slab with a minimum thickness can I just figure the tube sizing, space,etc. as normal? I do not see any reason to isolate the slabs from each other. There is a limit as to how high the second slab can be raised, doors and such. Thanks for any help.
