How do you figure out system water content?
stevo_2
Member Posts: 22
Does anyone know how to figure out system water content?I am assumeing there is a formula for the size pipe you are using. say Im using 3/4 pipe with 130 linear feet of fine/line 30 and 50 feet of 3/4 pipe. Is this all the info i need to figure out this quagmire?
figure
the area of your pipe in feet multiplied by the total length...that's the volume of water. Then multiply the cubic feet by 7.48 to get your total gallons. area of a circle is Pi x radius squared. I suppose you'd have to add the capacity of your boiler too. Just a thought from a non-professional in the industry but an engineer.0 -
If
yo do a lot of sizing get a copy of this software.
Just the pipe
or the whole system capacity? 150 feet of 3/4 and 50 feet of 3/4 baseboard would be 4.83 gallons. But fittings would add a tiny bit.
I use a Hydronic Design software from www.hydronicpros to do this calc. They have a free demo at the site that may allow you a one time try.
A good program to own if you do this type of work.
hot rod
