Water loss
Kay
Member Posts: 10
What can cause water loss in a steam boiler. Everything seemed fine until after my furnace was cleaned. I am still using water, even though I am only heating hot water. Please help!
water loss
Does it have vents?0 -
I assume you mean radiator vents...yes, all vents were recently replaced.0 -
What brand boiler................
sounds like you may have a leak in a section.
We had two in the last year that started to leak after a "clean out"/annual service. What we found was that the stuff on the heat exchanger was sealing a small pin hole and after removing it the leak started. John@Reliable0 -
Thanks, that may be a possibility, but I had the boiler shut down for two days while I was away, and there was no water loss. It seems to be sizzling at the top of the sight glass (invisibly) after the burner shuts off.0 -
Hmmmmmmm! Kay
If the "water" leak is above the water line,it will only "leak" when on. What happens is as water is heating up steam(water) is leaking out hole into chimney. Very easy to tell in cold weather as steam will look like white smoke out of chimney, in warm weather we take jacket off and any clean out plates to see into heat exchanger, sometimes it's as easy as just overfilling the boiler with water and look for water running into combustion chamber. The reason I asked for brand, some have a track record and I might be able to tell you where to look. Hope this helps John@Reliable0 -
The name on the boiler is Thatcher, and Wayne is on the burner.0 -
Thatcher went out of biz
over 20 years ago. More like 30! They were located in Grawood, NJ about 15 minutes from here (Rahway, NJ).
Sounds like the upper gage glass grommet is leaking if you hear a sizzle at that joint. Hopefully the boiler is not leaking internally above the water line.
If you wish, I'd be honored to take a look. I suspect you're not that far since Thatcher had a very small distribution area.
(732) 388-1794. Ask for Ken
Kay,
if you're close to Ken (north Jersey area) use him. He really knows his steam!
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Thanks
> on the burner.
Thanks to all for your suggestions. Ken, you are right, I am located in Morris County. I have written down your number. I have a "contract" with my local service company, so I guess I have to check with them first.0 -
Thanks
Ken
believe it or not we have quite a few Thatcher Boilers here in Auburn ME. Go figure.
Regards,
Robert0
