Hydronic system antifreeze
D. Andrews_2
Member Posts: 11
Can someone give information reguarding the effect of anit freeze and BTU output of water. Does adding anti freeze in a system change the amount of heat transfer to the water?
I've been told that you lose 15-20% of your btu,s,depending on your percentage of attifreeze0 -
I don't like the stuff.....
period. It has it's place but I avoid it at all costs. To many side effects. kpc
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
For an excellent discussion
For an excellent article on
the use of anti-freeze in HVAC systems go to
http://www.raypak.com/afreeze.htm
It works in every automobile running up and down the road regardless of location. You shouldn't be afraid of it in a hydronic system.0 -
antifreeze
A 50/50 mix will lose about 10% conductive efficiency in the system because you've changed the density of the fluid. You also increase expansion rate and usually have to step up the tank size on larger systems.
antifreeze
Thanks to all of you who responded. Your information was very helpful0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
