hydropac boiler
kevin coppinger_4
Member Posts: 2,124
Does any one have a suggestion to replace an old hydopac wall hung boiler? about 45K input.It needs to be natural draft as the old one is and it vent into a common vent/chimney w/ other condo units...there are no outside walls in this condo unit to get a vent through...only needs to be heat, not a combo unit. Stanard baseboard heat distibution.I can't think of a unit... TIA kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
You might want to scope out
The Weil McLain AHE.
Great apartment house unit. The fresh combustion air vent may be hairy.
AHE is power vented....
I can't use that...it would effect the other units' draft. kpc
All of the Wall hung boilers
Are usually fan assisted and want sperate vents. Does it have to be wall mounted? Could you build a platform or shelf that could hold 200 lbs? The Crown Aruba and Slant/Fin Sentry have very small under 50K BTU cast iron nat draft units. About 200lbs filled with water. Laars Mini-therm JV is also a small copper fin boiler. How many boilers vent into the same chimney now?0 -
Ole 'Hydro-deal...
There is a great wethead by that goes by the name of Gerry Wagner.I believe he can be of great assistance in this matter.Please contact him at gwagner@walesdarby.com or call him @ 732-560-1001.0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
