Non Ugly Pipe Insulation
prm_8
Member Posts: 13
I'm looking for pipe insulation that doesn't look like junk. We have a nice panel for a wall-hung boiler, circulators mounted square and true, nice straight and square copper work. Where can we find insulation that doesn't look like it escaped from a 1950's factory. The tees are particularly ugly. Any recommendations?
This stuff works nicely
Made by Knauf. Available at most plumbing supply houses.
Try this link www.knauffiberglass.com/index.cfm?fuseaction=prd.dspProdDetail&ID=1
EmcoLok
I've been very happy with the Emcoloc brand of neoprene. Very easy to cut in the miter box and it handles easier than other "competitive" pre-slit/glued neoprene. If you're doing large sttel pipe, try Zeston pipe covers and fitting covers, which work over fiberglass insulation.
I agree ,
With Paul on the Imcoloc(sp.) I've used it in the cold and the warm, and the cover tape comes off nicely, as opposed to some of the rubber type cover. It's a bit stiffer to compliment cutting 90° and 45° corners. Stiff enough to turn the whole piece to "split up" position in one turn of the hand, as opposed to working your way down the tube.We all carry the proper sized drills for making the cover fit directly into walls and holes too! Chris0 -
Thanks for Tip, (its \"Imcolock\")
thanks for the good info...looked it up. The product name is "Imcolock". The url is:
http://www.rbxcorp.com/mechanical/imcoa.html
Also found and attached the pdf for it.
Nick0
