Flexible Copper in boiler run
jcurran
jcurran Member Posts: 1
Hello -
Looking for advice - is it safe to use flexible copper for a 3' section of a boiler run? It's 3/4" copper and my boiler is ~119,000 BTU. If so, do you recommend solder joints or compression?
Thanks!
  • Robert O'Connor_6
    Robert O'Connor_6 Member Posts: 299
    Yeah
    Its acceptable to use soft copper for fitting baseboard etc. Usually the rolled copper is at least L copper.
    I never use compression fittings . I always solder with 95/5
    Regards,
    Robert
    ME
