Flexible Copper in boiler run
jcurran
Member Posts: 1
Hello -
Looking for advice - is it safe to use flexible copper for a 3' section of a boiler run? It's 3/4" copper and my boiler is ~119,000 BTU. If so, do you recommend solder joints or compression?
Thanks!
Thanks!
Yeah
Its acceptable to use soft copper for fitting baseboard etc. Usually the rolled copper is at least L copper.
I never use compression fittings . I always solder with 95/5
Regards,
Robert
ME0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 48 Industry Classes
- 49 Job Opportunities
