pressing questions(pro-press that is)
Dave Palmer_3
Member Posts: 388
bit the bullet and bought a propress today.My question is (Chris?)when I press a joint will the joint "shift" when pressed or stay square and plumb? I hate pipes that aren't level and plumb.Thanks Dave
Dave
Its a learning curve .
Yea it will pull alittle to the side. You need to offset a little before you pull the trigger.
Good Luck
Scott
The bigger the fitting,
The more the offset you'll find. Patience and practice are the best teachers. It's a b($%@ to do piping in the air by yourself, so I suggest some help when you have to.(the cordless model gets a bit heavy after a couple of hours of it being overhead) Keep pluggin Dave, you'll learn. I have great expectations of seeing the first job. Chris0 -
thanks guys
going to do a replacement boiler tommorrow w/ all propress.Going to do as many as I can.My old man looked at the tool today and said "I don't want to know how much do I?",I just smiled and kept walking.I'll post by Friday,Dave0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
