Gravity flow through circ pump?
Scott Toenniessen_2
Member Posts: 14
Is there any need to add a zone valve to prevent gravity flow through a circulator pump on a hot start (tankless coil in use) boiler? The system I thinking of was originally gravity - now forced - so much of the piping is designed for and probably encouraging gravity flow. It is one zone so no zone valves.
- Scott
- Scott
You need a flow check, or IFC pump.0 -
gravity flow
been there,
you do need a flow check on the main or your customer will call about 6 hrs after you leave complaining the heat will not shut off0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
