Solar system Information Needed
Constantin
Constantin Member Posts: 3,796
if anything was left. If the solar collectors are left open to the atmosphere like that, it would only be a matter of time before all liquid left in the collector would boil off. 3 years seems like enough time to get everything out... on the other hand, if they used glycol in the system, the distillation process over time may have removed all water but not all glycol.
Furthermore, if IIRC, glycol also raises the boiling point of water. Only a solar expert could probably tell you for certain if solar systems can sustain temperatures where glycol mixtures boil off altogether. My guess as a layperson/mere HO is that the blue sludge is some sort of decomposed glycol that has evaporated from the solar section and condensed inside the cooler pipe section inside home
  • John@Reliable_9
    John@Reliable_9 Member Posts: 122
    Would anything be left?
    Have a customer who removed solar water heater 3 yrs ago but left panels on roof. We installed a new boiler 6 months ago and removed old piping & shutoffs to roof just to get out of the way, nothing came out of pipes at that time. Now customer needs to remove panels for a new roof and roofer is concerned that panels still have "stuff" in them. Customer now tells me that since we removed pipes & shutoffs they have been dripping something lite blue. I'm thinking maybe just condensation/leftover mix from panels. Does this sound right?
  • John@Reliable_9
    Constantin , layperson here too ................
    when it comes to solar systems, thanks for your input.
    John@Reliable
  • Scott25
    Scott25 Member Posts: 30
    oil
    Recently worked on tearing out an old solar system that had an oil product as the heat transfer fluid. I Cut open some copper pipe from that job today and the copper still had a film on it. Maybe what ever was used is getting warmed and gravity is taking its toll slowly. Just a guess
  • Wardner
    Wardner Member Posts: 20
    Location?
    Where is the job located?
    Kinda sounds like "stick 'em on the extra work" senario.
    Home owner should advertise. Somebody with an aerial lift might remove the collectors at no cost. HO is at no risk for roof damage as it is being replaced. Plug the collector ports with corks.
  • Duncan_13
    Duncan_13 Member Posts: 20
    Light blue
    Light blue would probably be a copper compound like copper sulphate, maybe caused by glycol.
    I agree that anything that was in there should have been cooked away in three years time.
    The only thing I can think of is this...
    At night, the panels cool down. The warm, moist air in the house is migrating up into the panels. When it hits the cool surface of the panels, the moisture condenses.
    Eventually, under the right conditions (several cool, cloudy days), enough condensate builds up inside the panels to start draining out. So yes, I think you're on the right track.
    Just a guess.
  • John@Reliable_9
    Thanks, All &Duncan
  • S Ebels
    S Ebels Member Posts: 2,322
    What planet do you need info on??
    Sorry, couldn't resist. My bad. (G)
