Baseboard copper pipe thickness
Mark_24
Member Posts: 9
I just purchased fin tube baseboard radiators. I used 3/4 copper type L under the floor, up through the floor, then to my surprise a type M (I think cause of thickness)baseboard fin tube assembly! Man this stuff is thin. Is this the industry standard? Or did I buy real cheap stuff?
BB tubing thickness
I think it's even thinner than type M. Maybe we should call it type N.
Thats the industry standard
Maybe a manufacturer can shed some light on this. I was allways told that the tubing was slid thru the aluminum fins and then a swedge was drawn thru the tubing to expand it and grab the fins. Don't know what size tube it is before the swedging.
Any one know the process.
Scott
You have it right, Scott.
> swedging.
> Any one know the
> process.
> Scott
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 237&Step=30"_To Learn More About This
> "Find A Professional"_/A_
> swedging.
> Any one know the
> process.
> Scott
> _A
When finished, if it is Slant/Fin, it is rated at 200 PSI at 250° F., on our lowest rated model, and some models have a higher pressure rating.
Thinner metal transfers heat to the fins faster.
Noel0 -
So Noel
Could you find out what tubing is used ? Is it made just for the BB manufacturers ?
What schedule is it ?
Scott
It's custom
It isn't even 7/8" O.D. until it gets expanded within the fins.
I'm not sure how it is labeled, but it is made expressly for expanding to 7/8" O.D. within baseboard fins and to meet and exceed test pressures afterwards.
It's special tube.
Noel0 -
if it was any thinner it would be reynolds wrap lol0 -
So , the swedge
is part of the manufacturing process ? We use Argo and almost every swedge comes bent in , so we cut em em out anyways .0 -
)) SO!>>>.....
Type O copper held together by brute force of the fins:)) I love it.I always Knew there was some Engineering involved))) any thinner I think we could Read Thru it!
Is it
Swedged or swadged?0 -
Ron
Your talking about the Female end. what Noel is saying is the whole tubing is expanded after it has the fins around it. It expands to grab the fins. Thats what all that oil is.
Scott
Ahh , I get it now
Slant Fin doesn't go crazy with the oil , or they use a different type because this Argo baseboard - on the first heatup it feels like your up in the clouds with all the white smoke from the oil burning away .0 -
Oh it's thin alright
and a bit of a pain to cut with a tubing cutter. But it works!
Can't say I have ever seen the tube fail. I've been installing Slant Fin since the 1960's, when I helped my Dad.
Make sure you ream the burr, you'll get a big one with a dull tubing cutter!
hot rod
Its neither....
It is swaged.
(v. t.) To shape by means of a swage; to fashion, as a piece of iron, by forcing it into a groove or mold having the required shape.
THe A is a long A. Pronounced S-U-WAGED
ME
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
