Draining Hot Water Radiator Diverter-Tee System
Mike Grady
Mike Grady Member Posts: 1
How do i drain diverter-tee hot water heating system w / stand-up radiators w / bleeders on some radiators.
  • Big Ed
    Big Ed Member Posts: 1,117
    Drain System
    There should be a drain valve on the bottom of the boiler. I would use a pump and pump it down. You also need to let air into the system to replace the water as well as open any flow checks and zone valves....
  • bob young
    bob young Member Posts: 2,177
    shut boiler electric switch, shut water supply valve open draw off at bottom of boiler open air vents on top floors. thats it!! let er go gallagher
