Draining Hot Water Radiator Diverter-Tee System
Mike Grady
Member Posts: 1
How do i drain diverter-tee hot water heating system w / stand-up radiators w / bleeders on some radiators.
Drain System
There should be a drain valve on the bottom of the boiler. I would use a pump and pump it down. You also need to let air into the system to replace the water as well as open any flow checks and zone valves....0 -
shut boiler electric switch, shut water supply valve open draw off at bottom of boiler open air vents on top floors. thats it!! let er go gallagher0
- 167 Indoor-Air Quality
