Wirsbo(mk)
Mike Kraft_2
Member Posts: 400
Does Wirsbo make a Eurokonus adapter for the Multipress system?Or do we still use the compression QS style?
TIA,
cheese
TIA,
cheese
Eurokonus
What the heck is that?
In English
FELCIE................manifold adapters for combicor.I am using combicor with Oventrop manifolds.Why you ask....cuz I can:)I want to try out the SS manifolds.But would like to install all multipress fittings.My current catalog does not show them.
CHEESE!!!0 -
OK
Let me check the book...0 -
Wirsbo
shows their multi press fitting with a manifold adapter part # D4020500 Connects to their TruFlow manifolds as well as the brass ones. Available in 1/2" and 5/8"
Have you tried their TruFlow manifolds? We've used a bunch and LOVE them.0 -
WOW
If it had teeth it woulda bit me...........3 forehead slaps:)
thanks Felcie............you really should go to wetstock......I'm flying solo this time.Dont snooze...cuz you'll lose0 -
Wetstock
Wish I could,but I'm going to be visiting the big Mouse in Disney Land with the kids.I'll give you guys a big wave when I fly over...Listen for me I'll be yelling CHEEEEEEEEEESE!!! from 30,000 feet.
Are you planning on going to Boston for the RPA/ISH-NA show in the fall?0 -
it's
possible..........chances are favorable.
cheese...........say hey to the head rat;)0
- 167 Indoor-Air Quality
