Wirsbo(mk)
Mike Kraft_2
Mike Kraft_2 Member Posts: 400
Does Wirsbo make a Eurokonus adapter for the Multipress system?Or do we still use the compression QS style?
TIA,
cheese
  • John Felciano
    John Felciano Member Posts: 411
    Eurokonus
    What the heck is that? :)
  • Mike Kraft_2
    In English
    FELCIE................manifold adapters for combicor.I am using combicor with Oventrop manifolds.Why you ask....cuz I can:)I want to try out the SS manifolds.But would like to install all multipress fittings.My current catalog does not show them.
    CHEESE!!!
  • John Felciano
    OK
    Let me check the book...
  • John Felciano
    Wirsbo
    shows their multi press fitting with a manifold adapter part # D4020500 Connects to their TruFlow manifolds as well as the brass ones. Available in 1/2" and 5/8"
    Have you tried their TruFlow manifolds? We've used a bunch and LOVE them.
  • Mike Kraft_2
    WOW
    If it had teeth it woulda bit me...........3 forehead slaps:)
    thanks Felcie............you really should go to wetstock......I'm flying solo this time.Dont snooze...cuz you'll lose
  • John Felciano
    Wetstock
    Wish I could,but I'm going to be visiting the big Mouse in Disney Land with the kids.I'll give you guys a big wave when I fly over...Listen for me I'll be yelling CHEEEEEEEEEESE!!! from 30,000 feet.
    Are you planning on going to Boston for the RPA/ISH-NA show in the fall?
  • Mike Kraft_2
    it's
    possible..........chances are favorable.
    cheese...........say hey to the head rat;)
